bsholbrook
Dec 16, 2016Apprentice
iOS devices
Running the Orbi formware 1.40.0.18 I've now experienced a couple of cases where an iOS device will infrequently get dropped off the network going from full signal to no wifi for upwards of 30 seconds...
genobkk
Dec 16, 2016Star
I have noticed a few dropout n iPad Pro and iPhone 7 plus, it drops for a second,iPhone goes to 4G then wifi comes back, my iPad is wifi only so I just see the signal drop completely then reconnects. This is not to often but it happens. An older iPhone 5s had the same issue. I have an Android box connect via LAN to satalite and no issues. Once again this issue does not happen often but I suspect it could be cause of a few VOIP calls drops whine useing Line2 on my iPhone 7 plus.
bsholbrook
Dec 17, 2016Apprentice
i also have an ipad pro that is wifi only that dropped once yesterday. This ipad is running the latest 10.2 ios, so it is as up-to-date as possible.
- bsholbrookDec 17, 2016Apprentice
Today I've not had any network issues ... crossing fingers.
- TomMacDec 18, 2016Guru
I downgraded to .16 and last night had no dropout on the Ipad. Wondering is it the older sw fixing or something else going on
- DarrenMDec 19, 2016Sr. NETGEAR Moderator
Thanks Tom for testing the old firmware to help me gather the info for the engineers if anyone else is experiencing connection problems with the .18 firmware let me know.
DarrenM
