bsholbrook
Dec 16, 2016Apprentice
iOS devices
Running the Orbi formware 1.40.0.18 I've now experienced a couple of cases where an iOS device will infrequently get dropped off the network going from full signal to no wifi for upwards of 30 seconds...
DarrenM
Feb 21, 2017Sr. NETGEAR Moderator
NETGEAR is aware of an issue affecting some users where wireless client devices frequently disconnect/reconnect from the Orbi WiFi network. We’re actively working on the issue and hope to have a solution soon.
I have seen a small fix from some users saying that they lowered the power level of the wireless on the 2.4 ghz band.
DarrenM
Tingyunliu
Feb 21, 2017Star
Could you please share how to lower the power level of the wireless on the 2.4 ghz band? Like to try.
- DarrenMFeb 21, 2017Sr. NETGEAR Moderator
log into orbi go to Advanced-Advanced setup-wireless settings then adjust the Transmit Power Control lower and test if that helps.
DarrenM
