bsholbrook
Dec 16, 2016Apprentice
iOS devices
Running the Orbi formware 1.40.0.18 I've now experienced a couple of cases where an iOS device will infrequently get dropped off the network going from full signal to no wifi for upwards of 30 seconds...
bsholbrook
Apr 04, 2017Apprentice
Not able to get into router at the moment, from memory I believe the setting is cts or rats or similar and you want to set the value down from 2347 to 2346. Hopefully this is close enough instructions to get you where you need to be to make the change
