Borgling
Nov 28, 2016Follower
IP address for Satellite
I set my Orbi Router to act as an Access Point and gave it a manual IP address. (works without a problem) Is it possible to set the IP address also for the Satellite? Because at the moment it automa...
- May 24, 2017
you can put the satallite orbi in static
i am using orbi as AP mode i go to my router i get Address Reservation and add my RBS50 with IP i want and MAC and restart the device i get the IP what i want it work fine
peteytesting
Nov 28, 2016Hero
hi
you cant set a static ip address on the sat as far as i know but you can access whatever router you are using and reserve an ip address for the sat within the dhcp pool so it gets the same address every time
