jerryhoyin
Jun 01, 2017Follower
Ip cam
I cannot connect my ip cam after i changed to use Orbi AC3000. How to set up to connect it again with orbi?
1 Reply
- superben79Apprentice
i had a regular router with 5 ip cams (3 differet brands). i switched to orbi and all cams connect with no issue. i used the same ssid and the same passphrase. nothing else i needed to do special in the cam or orbi. u can reset your cam and try from scratch.
