futelihut
Apr 04, 2019Aspirant
IPv6 DHCPv6 Prefix Delegation
Hi
My ISP requires Prefix Delegation for IPv6 support.
Is there a way to configure the RBK50 router to fetch prefix delegation from my ISP?
Or is it not supported?
/Morten
Sort By
What is the Mfr and model# of the ISP modem the NG router is connected too?I believe under Advance Settings there is IPv6 menu and a drop down menu. Select from the menu of IPv6 options. ISP should be able to tell you which one to use.
Review the user manual starting at page 39:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
- futelihutAspirant
Hi
My current firmware is V2.3.1.44
My modem is DSL pass through.
The information i got from my ISP is that my ISP is that my router must request prefix delegation over DHCPv6.
I have tried DHCP, Auto config, Auto Detect and pass though. But the router did not get any thing.
Just to be on the safe side, i have tried to plug my laptop directly to the modem, and i got a prefix delegation immidiatlly
/Morten
I would contact NG support ask about this.
