RedBatman89
Jun 24, 2020Guide
Is firmware 2.5.1.16 stable for rbk23?
I'm asking since I still have firmware 2.3.5.26 on mine and aside from an odd bug where one of my satellites gets low wifi speed and I have to reboot it every once in awhile, it's still working very w...
Jun 25, 2020Guru - Experienced User
Seems to work for others:
I recommend manually downloading the FW files, update the RBS first, then RBR lastly, then factory reset and setup from scratch.
