va3lim
Jan 05, 2019Aspirant
Is it better to position Orbi router on higher level than satellite?
I’ve a Netgear Orbi AC3000 (RBR50 & RBS50). In general, I think it’s better to place a router at a higher floor on a multi-story house. right? However, I’m a bit confused why Netgear recommended to pl...
Jan 05, 2019Guru - Experienced User
30 feet is recommended in between Orbi router and satellite to begin with depending upon building materials.
va3lim wrote:
I’ve a Netgear Orbi AC3000 (RBR50 & RBS50). In general, I think it’s better to place a router at a higher floor on a multi-story house. right? However, I’m a bit confused why Netgear recommended to place the router on the main floor and the satellite on the higher floor. Does it matter which is placed higher than the other? Should I place the satellite on the 2nd floor & the router on the main floor? I don’t plan to buy another satellite (not planning for satellite-router-satellite type of setup) as the current system is able to cover my entire 2000 sq ft house. Thanks in advance for your comments.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
