va3lim
Jan 05, 2019Aspirant
Is it better to position Orbi router on higher level than satellite?
I’ve a Netgear Orbi AC3000 (RBR50 & RBS50). In general, I think it’s better to place a router at a higher floor on a multi-story house. right? However, I’m a bit confused why Netgear recommended to pl...
va3lim
Jan 07, 2019Aspirant
So as long as the router & satellite are within 30 ft, it does not matter which is placed higher. Correct?
PS. I was under the impression that the router has a stonger signal than satellite.
Jan 07, 2019Guru - Experienced User
No shouldn't matter. There will be wifi coverage and if you can get the wifi over lap in a sweet spot between the Base router and Satellite, you'll be fine.
