OCGrumpa
Jul 21, 2017Follower
Is it possible to use 2 RBR50s, connecting 2 RBS50s to each and still maintain a single mesh network
Hoping to use Orbi to set up wifi on a church campus. The buildings are in a u shape around an open courtyard. Rough outside dimensions of the U are 400 ft x 200 ft. I know from our existing set ...
DarrenM
Jul 24, 2017Sr. NETGEAR Moderator
Hello OCGrumpa
If you are using 2 RBR50s then there would be 2 SSID and it wouldn't be seamless moving around. And you shouldn't have much issue on the overlap if they are on different channels.
DarrenM
