JaapB
Sep 08, 2018Aspirant
Is RBS 40 satellite compatible with RBK53-100ES ?
I tried to link my extra bought RBS40 satellite (my third satellite) to my existing Orbi RBK53-100PES home wifi system. But I believe this is not compatible.
What can I do to link and add this...
Blanca_O
Sep 09, 2018NETGEAR Employee Retired
Hi JaapB,
Welcome to NETGEAR Community!
You can connect the RBS40 to the RBR50 just by pushing the sync button on both the Orbi router and the satellite.
Blanca
Community Team
- Blanca_OSep 12, 2018NETGEAR Employee Retired
Hi JaapB,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- JaapBSep 13, 2018AspirantYes, thanks very much, but I need some more help. How can I fully reset the username and password as I forgot how I changed admin and password. I did not wtite down my new settings, stupid stupid .... Can I use for this an erhernet cable between the device and my Mac which has Safari browser. What then to do ? Thanks ! Regards, Jaap
- FURRYe38Sep 13, 2018Guru - Experienced User
You'll need to factory reset the Orbi router and satellites and set up from scratch. Walk thru the set up wizard with a connected PC and this time write down important information for safe keeping and future needs.
