sleepbaby
Mar 05, 2018Guide
Is there any good news ????
Firstly I would like to welcome new members to the Netgear community and secondly a hello to existing members, I would also like to add that I am on my second Orbi kit(RBK33) after having numerous pr...
- Mar 05, 2018
FURRYe38 Really? Exactly which others did those solutions help? Seriously, who had their disconnect issues solved by what you suggested?
Those are just blind shots in the dark and just spreads confusion and doubt.
Disabling beamforming only helped with nest cams in the early 1.x series when netgear didn't have that basic feature working properly. It's had no impact on disconnect issues since then.
Fast Roaming? That's an AP-side feature, not known to the clients. It's not going to change anything, it's not 802.11r. It would only impact roaming anyway.
Daily Chaining? What? At best that would be a performance only feature. Nothing to do with disconnects.
Disabling Mu-MIMO support? Again, that's performance related. And, if you had to disable that feature, you'd want to return the unit. That's a core feature of modern wifi. That's like saying "see if welding the trunk closed makes the car ride more smoothly". If it does, you still have a major problem.
Stop with the confusion and illogical suggestions!
webminster
Mar 05, 2018Luminary
Netgear has to date not committed to publishing any news on anything they're tracking or working on, or any expectations or ETAs on firmware. You just have a operate in the dark, and trust your gut about whether you're happy enough to keep it.
- sleepbabyMar 05, 2018Guide
Thanks for getting back, in that case I will wait until i get closer to my second 30 day return window and decide then if i will return or keep the Orbi.
