sleepbaby
Mar 05, 2018Guide
Is there any good news ????
Firstly I would like to welcome new members to the Netgear community and secondly a hello to existing members, I would also like to add that I am on my second Orbi kit(RBK33) after having numerous pr...
- Mar 05, 2018
FURRYe38 Really? Exactly which others did those solutions help? Seriously, who had their disconnect issues solved by what you suggested?
Those are just blind shots in the dark and just spreads confusion and doubt.
Disabling beamforming only helped with nest cams in the early 1.x series when netgear didn't have that basic feature working properly. It's had no impact on disconnect issues since then.
Fast Roaming? That's an AP-side feature, not known to the clients. It's not going to change anything, it's not 802.11r. It would only impact roaming anyway.
Daily Chaining? What? At best that would be a performance only feature. Nothing to do with disconnects.
Disabling Mu-MIMO support? Again, that's performance related. And, if you had to disable that feature, you'd want to return the unit. That's a core feature of modern wifi. That's like saying "see if welding the trunk closed makes the car ride more smoothly". If it does, you still have a major problem.
Stop with the confusion and illogical suggestions!
Mar 05, 2018Guru - Experienced User
While your in your waiting period, try disabling any of these options you might have, MIMO, Daisy Chain, Fast Roaming or Beamforming to see if you notice any differences. Has help others. NG is working on FW issues.
- t_kMar 05, 2018Luminary
