ldehoyos208
Aug 11, 2019Aspirant
ISP said needed an N router
Due to rural area, I am now using Blazing Hog Internet and was told that I needed to get a N type router. I purchased a Orbi 2200 which I was tod supported N and AC.Does it make a difference and is there a way to switch in between as I am having a hard time utilizing the wifi capability on my new Orbi?
N type is an old wifi standard.
Orbi 2200 isn't a Netgear model number, so it is hard to know where to point for the details, but a typical "Data sheet" will say something like: "IEEER 802.11a/b/g/n/ac".
See the "n" and "ac" in there?
All newer devices are "backward compatible" with anything you own that needs N type.
But it is hard to see how the wifi standard you use enters the picture for your Internet service provider. How does it deliver the Internet?
Whatever router you buy, you will need a modem to get whatever technology Blazing Hog uses to deliver your Internet.
Searching for Blazing Hog Internet just leads to a page that looks like a scam.
You don't need to switch between them. They happen side by side.
What "hard time" are you having?
- ekhalilMaster802.11n or Wireless N supports a max of 300 Mbps throughput.
Orbi RBR20 or RBR40 (AC2200) -which I believe you’re referring to- supports up to 866 Mbps for 802.11AC fronthaul links and 400 Mbps for 802.11n fronthaul links.
By saying that your ISP specifies 802.11n as a requirement, I understand that the data rates that you get from your ISP will never be more than 300 Mbps, right?
If so then Orbi supports higher throughput that what your ISP requires. - ldehoyos208Aspirant
Very slow connectivity. When I signed up for the service I was informed their service was 5 times faster than a mobile hotspot. I attempted to connect to their service and it was so slow that none of my work applications worked.
What ISP service company are you signed up with?
What is the Mfr and model# of the ISP modem the NG router is connected too?What wireless devices are you connecting to the Orbi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
ldehoyos208 wrote:Very slow connectivity. When I signed up for the service I was informed their service was 5 times faster than a mobile hotspot. I attempted to connect to their service and it was so slow that none of my work applications worked.
