j2boston's avatar
j2boston
Issue with connecting to MYCLOUDEX2ULTRA on ORBI Satellite
I currently have the RBR50 and 2 satellites and a mycloudex2ultra connected via ethernet cable to the RBR50 router.  Previously, I never had a problem accessing the share drives on the mycloud. When my HP Laptop computer is connected to the Satellite via an ethernet wire, I am unable to access the mycloud shared drives.  However, if I move the laptop into the family room, it is able to connect to the RBR50 Router via wifi no problem and is able to access the mycloud.  There seems to be something blocking the satellite from letting the computer access the drive. I looked at other threads and confirmed the Enable MU-MIMO setting in the advanced setup is unchecked.  I have also checked the orbi attached devices and can see the mycloud attached.  Does anyone have any suggestions on what might be preventing a Satellite to Windows 10 computer from access the Mycloud?
Thank you,
  • CrimpOn's avatar
    CrimpOn
    Do both ethernet and WiFi function the same on the satellite and function the same on the router?
    i.e. When the laptop connects to the satellite with either ethernet or WiFi, it cannot connect to the MyCloud?
    When the laptop connects to the router with either ethernet or WiFi, it does connect to the MyCloud?
    • j2boston's avatar
      j2boston
      Yes, when you try to connect via wifi or ethernet on the Satellite, it does not connect to the Mycloud.
      When you connect the computer to the Orbi Router by wifi or ethernet it does connect to the Mycloud.
      • CrimpOn's avatar
        CrimpOn
        This pretty much rules out any WiFi settings as part of the problem (or part of the solution).
        This scenario being obviously impossible, we need someone with a lot more smarts than I have to explain it.
        Sorry
