Trishan
Aug 22, 2022Aspirant
Issue with Netgear Orbi Mesh Router system: Router: RBR40 (2 Satellites: RBW30)
The problem I have is that my computer keeps connecting to a satellite which has a poor signal instead of the satellite which is closest to my computer. I want to force the computer to con...
Trishan
Aug 31, 2022Aspirant
Thanks for the response. My computer randomly started showing up in the device list so I think that i'm OK on that front. However, I can't seem to solve the issue of the laptop connected to a weaker satellite when there is a stronger satellite available. I have a Macbook so don't have the same setting as the Windows screenshot you posted. In fact, i can't find anything even remotely equivalent.
Any other ideas?
CrimpOn
Aug 31, 2022Guru - Experienced User
Does your MacBook have a page similar to this one:
https://kb.netgear.com/25191/Configuring-TCP-IP-and-Proxy-Settings-on-Mac-OSX
The page did not show what is on the Hardware tab.
- ekhalilSep 01, 2022MasterSorry, didn’t see that it’s a MacBook! In MacOS under networks (see the good link the was shared by CrimpOn) you can find some of these settings, but there are much less controllable parameters than what’s in Windows.
