gui83
Jun 30, 2020Follower
Issue with satelite - not connecting, not resetting
Hello,
I have a mesh solution with 2RBS20 + modem. Everything has been working perfectly for 12 months - but suddenly one of the satellites stopped working. It shows as "not connected" on the app and the light (next to the power button) is bleaking amber (10 flashes, then a pause). I have tried to reboot and did multiple attempts of factory resets. Nothing is working. The amber light keeps bleaking and it does not work.
Thanks a lot for your suggestions !
1 Reply
Be sure the RBS are using same version of FW as the RBR.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Did the RBS appear on the RBRs web page?
Press the back reset button for 15 seconds then release. Then try to sync the RBS.
