KenStorm
Feb 28, 2018Aspirant
Issue with Static DHCP assignment (2.1.2.18)
Bug? Scenario: A network device has already been on the network and given an IP address by Orbi DHCP. You assign a static IP (in order to group similar items) which is outside the range of the DHC...
Mikey94025
Feb 28, 2018Hero
Does it work when your "static" Address Reservation is within the DHCP starting->ending range? I don't think you can tell Orbi to use a restricted DHCP range and then expect that it will vend "static" DHCP addresses outside that range.
I have both types of reserved addresses, i.e., some that are within my DHCP range and some that are outside. But for the latter my clients are all setup to use a static IP (not DHCP) so Orbi is not involved with assigning the IP address to the client.
- KenStormFeb 28, 2018Aspirant
Would not the fact that a restart of the Orbi router cures the problem prove otherwise.
i.e. After a restart of the router the network device picks up its required (assigned) IP address?
Additionally this is the first router I have had that shows this behavour. Other routers it just works.
