KenStorm
Feb 28, 2018Aspirant
Issue with Static DHCP assignment (2.1.2.18)
Bug? Scenario: A network device has already been on the network and given an IP address by Orbi DHCP. You assign a static IP (in order to group similar items) which is outside the range of the DHC...
tucsontico
Mar 03, 2018Virtuoso
I have seen this behavior, too. In my case I simply let the ORBI resolve the conflict itself. Meaning, I assigned a static IP address to a device that was originally getting a random DHCP address. After the static assignment, the ORBI still showed the old DHCP address to the device. After allowing the ORBI to "settle down" about 15 minutes, I noted it began reporting the correct static IP address for the device. No reboot required. I believe the bug is in the ORBI GUI home page display. It appears to not update all the data in the graphical display of attached devices very often.
- FURRYe38Mar 03, 2018Guru - Experienced User
This should be fixed in next updated. We hope.
tucsonticowrote:I have seen this behavior, too. In my case I simply let the ORBI resolve the conflict itself. Meaning, I assigned a static IP address to a device that was originally getting a random DHCP address. After the static assignment, the ORBI still showed the old DHCP address to the device. After allowing the ORBI to "settle down" about 15 minutes, I noted it began reporting the correct static IP address for the device. No reboot required. I believe the bug is in the ORBI GUI home page display. It appears to not update all the data in the graphical display of attached devices very often.
