KrisG55's avatar
KrisG55
jhow do I change or add a phone number to my common account?
I need to add my phone number to my commom account,  also to use for two step verification
    • KrisG55's avatar
      KrisG55
      i guess that is it I also have an extender but its just not working like it says nor does any info work for it.  but i am trying to add my phone number to my netgear common account or the app so I can use it for 2 step verificqtion because when I had it there half the number was not visible and I was not recieving texts sent to that number.  so i can only surmise that it was entered wrong or changed some how.  been having alot of trouble with my neighbors getting into my system to sabotage my cameras
      • FURRYe38's avatar
        What product are you referring too? Model# is more helpful.
        I recommend you open a support ticket here and contact NG support for additional help and information:
        https://www.netgear.com/support/#
        Thank you
