Friendlyx
Jun 27, 2017Tutor
Keep Loosing Internet Connection with my Orbi
I recently bought an orbi from amazon and i love it because it reaches throughout my whole house unlike my old router. However, i have noticed that i have dropped internet connections at times. For e...
DBetts
May 23, 2018Guide
Firmware V2.1.4.10 is a disaster. Countless posts on various underdeveloped and poorly tested firmware versions. Most of us have countless hours of factory resets, and many of us have had the misfortune of sitting on the phone with helpdesk folks who have been hung out to dry trying to support a system that does not work.
I have had one period of approximately 2 months duration from February to mid April 2018 where the orbi system was relatively reliable. I don't know which firmware was making this happen, and as an end user, I shouldn't need to. In any event, need to know what firmware to roll back to, and how to disable auto update.
May 23, 2018Guru - Experienced User
Did you try a factory reset and set up from scratch with this last version?
What problems are you seeing that is a disaster?
I would try v2.1.3.4. Do a factory reset and set up from scratch.
Try this to disable auto update:
https://community.netgear.com/t5/Orbi/How-to-disable-auto-upgrade/m-p/1563577/highlight/true#M30872
