tandrew49's avatar
tandrew49
lack of knowledge/understanding
greetings,
I have an AT&T modem...trying to increase effectiveness in a fairly large home.  I have plugged in three orbi's.  One to the modem (RBR40) and one in an outlet about 15 feet away (RBS40) that I am using to boost a ring camera signal.  I have another plugged in an office (RBS20) that is not very far away from modem, but does have two thick plaster walls between them.
the unit at the modem and 2nd unit have the same network names.  the third orbi I purchased later and separately and it has a different network name.  I just realized this today as it seems like I am not getting much coverage.  when I try to connect to the third orbi with a different network name my devices cannot locate the network.  Do all three orbi's need to have the same network name in order for this to work.  I have tried using the password on the orbi and choosing each of the different security setting options but to no avail.
I really don't know where to go to find simple explanations about networking.  when I first got the orbi's they seemed to help but not so much now.  my home is two stories, older with a lot of plaster walls
any recommendations deeply appreciated.
peace
tom
  • CrimpOn's avatar
    CrimpOn
    The Orbi that was purchased used (which I do, also) probably was originally part of an Orbi package and set up with a different WiFi name.  The trick is to do a "factory reset" on this satellite (using the famous paperclip) and then "sync" it to the Orbi router.
    Factory reset involves sticking the end of a paperclip into the tiny "Reset" hole on the back of the satellite close to the power plug and holding it until the power LED turns amber and then begins to blink.  Can take 15-20 seconds.  Once it blinks, pull out the paperclip and the satellite will be reset.  Here is a link to doing a sync:
    https://www.youtube.com/watch?v=ePZSc7vnRlQ
    • tandrew49's avatar
      tandrew49
      I can get it reset, but cannot get it to sync.
      when syncing the satellites are they supposed to be close to each other and then moved to locations throughout the house, or are they supposed to be synced from the location they will be operating at.  none of these are really far form each other...RBR at the at&t modem, RBS40 only about 10 feet away, and RBS 20 about another 15 feet on the other side of the wall.
      one more question, after syncing how can I tell if they are working, or keep working, individually.  The RBS40 is syncing but not the other.
        tandrew49
        sorry, one more thing, the ring light on the rbs20 never changes color, just flashes white the whole time
