jayeldee's avatar
jayeldee
LAN woes RBR50 with new att gateway
PLease advise if this is not the right place to post   I have an Orbi rbr50 with 2 satellites. The master Orbi previously received a direct input from the modem & was connected to my iMac server v...
  • jayeldee's avatar
    Nov 15, 2025
    Thanks, Crimpon. I actually thought that could be the case after I wrote the above. So, I connected the mini to the orbi router and the home LAN appeared! I realize that by connecting the mini to the gateway via a separate port the mini would not know the LAN existed, but going through the Orbi, the LAN now could be seen.
    Thak you very much for jumping in so quickly.
