jayeldee
Nov 14, 2025Aspirant
LAN woes RBR50 with new att gateway
PLease advise if this is not the right place to post I have an Orbi rbr50 with 2 satellites. The master Orbi previously received a direct input from the modem & was connected to my iMac server v...
- Nov 15, 2025
Thanks, Crimpon. I actually thought that could be the case after I wrote the above. So, I connected the mini to the orbi router and the home LAN appeared! I realize that by connecting the mini to the gateway via a separate port the mini would not know the LAN existed, but going through the Orbi, the LAN now could be seen.
Thak you very much for jumping in so quickly.
jayeldee
Nov 15, 2025Aspirant
