styvy's avatar
styvy
Follower
May 09, 2022
LBR20 lte port forwarding not working
hi everybody
i have configured port forwadins http: 8080   but not working on LTELBR20
do i need static IP or no  for LTE
if a test with other router with IPS modem cable  and open port 8080 is working
 do you knows why is notworking
best regard
1 Reply
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hi styvy,
    I understand that you would like more information to successfully implement port forwarding on your LBR20.
    I have included steps below on how to port forward with the LBR20:
    • Select ADVANCED > Advanced Setup > Port Forwarding/Port Triggering. The Port Forwarding/Port Triggering page displays
    • Leave the Port Forwarding radio button selected as the service type.
    • Click the Add Custom Service button. The Ports - Custom Services page displays.
    • In the Service Name field, enter a descriptive name.
    • In the Protocol menu, select the protocol. If you are unsure, select TCP/UDP.
    • In the External Port range field, enter the port numbers.
    • Specify the internal ports by one of these methods:
    • Leave the Use the same port range for the Internal port check box selected.
    • Type the port numbers in the Internal port range field.
    • Type the IP address in the Internal IP address fields or select the radio button for an attached device listed in the table.
    • Click the Apply button. The service is now in the list on the Port Forwarding/Port Triggering page
    For more information on port forwarding please navigate to the link below (page 122):
    https://www.downloads.netgear.com/files/GDC/LBR20/Orbi_LBR20_UM_EN.pdf
    Best,
    Kevin
    Community Team
