macyak's avatar
macyak
Guide
Apr 16, 2018
LED ring solid white on Router
Yesterday my network went out in the middle of the day. I tried restarting the Orbi router, but it never recovered -- the ring remains solid white. I restarted several more times, and noticed that sometimes the power LED blinks green (although other times it remains solid green). I tried plugging it into a different outlet (based on advice from another post here) but that made no difference.
I decided to do a factory reset, but that doesn't work either -- Ive held the Reset button down using a paper clip for several minutes, but it has no effect -- the ring remains white and I can't connect to the router via wireless or wired connection.
The Orbi is 16 months old, so it's out of warranty. I have two RBS50 satellites, so I feel pretty deeply invested in this solution -- and besides this experince, it's worked well for us.
Anyone have any advice about how to proceed or anything else I can try?
  • FURRYe38's avatar
    Is the system working or is there a internet access problem?
    When you hold the reset button in, only hold it for 10-15 secons. Not minutes.
    Are you able to acess the routers web page at 192.168.1.1? If so, walk thru the set up wizard at this point?
    What is the Mfr and model# of the ISP modem the Orbi is connected too?
    • macyak's avatar
      macyak
      Guide
      I was actually able to revive the Orbi this morning by using TFTP to reflash the firmware. (Following the directions here). After that, the Orbi started up as normal.
      So it seems like firmware got corrupted. I'm guessing that the firmware started  auto-updating yesterday, and the update was still in progress when my wife restarted the router.
      • FURRYe38's avatar
        Ah kewl. Good to hear. I recommend manually updating FW with the FW files, using IE11 or FF browsers. Seen bad behaviors when using Chrome.
        Glad you got it working. Enjoy now.
