smojsak
Dec 29, 2018Aspirant
LED ring solid white
Hi.
I have a solid white light on my Orbi router but my satellites are with solid blue or red then blue.
I saw some people are having the same issues and said to download new firmware but w...
Dec 29, 2018Guru - Experienced User
What FW is currently loaded?
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
For RBR50 model routers you can find FW here:
https://www.netgear.com/support/product/RBR50.aspx
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
