Frizzy's avatar
Frizzy
Follower
Aug 20, 2018
Leviton Smart Decora switches randomly disconnecting
Anyone have issues with Leviton Smart Decora switches disconnecting?  I am having this issue and others have brought up that possibly forcing seperate SSID's for 5 and 2.4 might help, anyone notice success with that?
Netgear support can you look into how we can fix this issue?
  • FURRYe38's avatar
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Set up IP address reservations ON the router for the satellites and your devices. Wired or wireless connected.
