vhoog20
Jun 26, 2018Aspirant
LG SmartTV slow connections
I am experiencing problems with my LG SmartTV (LG 55C7V, WebOS3.5)
With my old WiFi I didnt experience any problems. Now that I have upgraded to the Orbi system I am having frequent issues with a v...
Jun 26, 2018Guru - Experienced User
Have you power cycled the TV or removed any wireless network settings from the TV then power OFF then back on and re-setup the wifi connection?
What is the distance between the TV and the Orbi router or satellite?
Can try disabling MIMO, Daisy Chain and Fast Roaming to see if this helps any.
Seems like the TV maybe connecting to 2.4Ghz rather that 5Ghz...Does the TV show which freqency it's connected too?
vhoog20
Jun 27, 2018Aspirant
Yes i tried. When i do a re-setup of the tv it works for 1, max 2 days and then same problem.
I also did a factory reset (thats what LG customer support told me to do. factory reset and use a wired connection :-( )
The tv connects to the main router. distance is just 6m/.
TV doesnt show frequency but in the orbi i see its 5GHz. And linkrate is always >300Mbps. Most of the time is >500Mbps
disabling MIMO, Daisy Chain and Fast Roaming dont seem to help so far
