nagendraprasath's avatar
Jun 09, 2020
Limited Connectivity on 5GHZ
My townhome is about 1600 sq.ft and below is my setup. Please note, the same setup has been working for the past one year.
Router in the living room
One satellite in bedroom
One satellite in the Garage
One satellite in the kids room (next to guest room)
Am using Android phone Oneplus 6T Mclaren.
Recently my wifi connection in the phone reports Limited connectivity in the first floor and its pretty much dont have internet connection. However WIFI signal is good. By default, my phone connects to 5GHZ. Not sure why it isnt switching to 2.4ghz, lets ignore that for a moment. Other phones which connects to 2.4ghz gets internet connection though.
Whenever phone connects (via 5GHZ) to satellites or is a bit away from main router, i loose internet connection. WIFI connection stays excellent.
Firmware:
Router RBR50 V2.5.1.16
Satellite RBW30 V2.5.0.2
Satellite RBS50 V2.5.1.16
Forgot to mention, Satellite RBS50 was recently added to the system. But i switched off and tried it, still the issue persists.
  • plemans's avatar
    How far apart are your satellites? 30ft minimum is recommended.
    You have quite a few satellites for a 1600sqft space. I found my home took significant speed hits when I had to many satellites.
    I'm in a 3200sq ft home plus 1200 sqft garage and I use a router and 2 satellites. when I had more than that, i had speed issues and roaming issues.
    have you tried removing a satellite or 2?
    • nagendraprasath's avatar
      nagendraprasath
      Thanks for the suggestion. Unfortunately it didnt help. I switched off all satellites except one, removed them from the router but still getting limited connection :(
      I had to use atleast one satellite at my garage where the main router's signal is weak. Moreover router + 2 satellites have been working good. Not sure what went wrong recently.
      • plemans's avatar
        What modem are you using?
        Does it work with just the router?
        If not, have you tried factory resetting and reinstalling the system?
