ConradSchiel
Mar 26, 2017Aspirant
Link TWO Orbi Routers and TWO Orbi Satellites ?
20170326 - The performance of my first Orbi and Satellite is so good, I bought another Orbi and Satellite. My question is simply, can I connect the new Orbi Router and Satellite to the installed sys...
- Apr 25, 2017
You may wish to try what I did with my two Orbi systems. I hope this works for you too.
1. Disconnect original Orbi Router ethernet cable from your internet Router
2. Disconnect original Orbi Router and Satellite from grid power
3. Connect Second Orbi Router by ethernet cable to your Internet Router
4. Complete Setup of Second Router and Satellite as per installation instructions.
5. Place original Orbi Router at one extreme end of your house and connect via ethernet cable to your internet router
6. Place original Satellte about a quarter of the width of your house from original Orbi Router
7. Place second Orbi Router at the opposite extreme end of your house and connect via ethernet cable to your internet router
8. Place second Orbi Satellite one quarter from the extreme end and from your Second Orbi router
9. Reconnect grid power, have a cup of tea or coffee, adjust positions slightly as needed.
Enjoy super connectivity all through your house and even outside.
onezerosix141
If your planning to run it under the same network, you just need to buy Orbi satellite.
