jcartersd's avatar
jcartersd
Follower
Aug 27, 2018
Loading firmware for RBK50 – Orbi AC3000 Tri-band WiFi System
I'm think I need to update my firmware and the only choice is RBR50. Is that the correct firmware for my RBK50?
  • FURRYe38's avatar
    Did you type in RBK50 Should come up. However yes...same as RBR50.
  • You just need to understand the letter codes.
    RBR = Orbi router
    RBS = Orbi satellite
    RBK = Orbi kit with router and satellite(s)
    So there's no firmware for the RBK because that's just packaging.
