TeamForrest3
Mar 24, 2018Follower
Log errors, need config help please. (BTHHB5/Orbi)
Hi
Up until yesterday I was using a Netgear Dm200 with my Orbi but was getting horrendous dropouts. I was unable to change it to modem only so I dug out my old BTHH5 from under the bed and reinstalled it in 'modem' only mode by disabling wifi banding and DHCP - having read some posts on how to do this, but I think I've gone askew somewhere!! :(
I've attached logs from the BT HH5 and Orbi RBR50 and screenshots of the IP setups (hopefully).
I know the BTHHB's are not particularly great devices and I am also considering replacing it with another modem if it continues to drop.
Any help greatly appreciated.
Thank you, Lauren
1 Reply
I would try the Beta:
The first wave to be released are only for the RBR50 and RBS50, which is used in the RBK50 and RBK53 (Costco) kits.
New beta FW avaialble. Get it while its hot of the press:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
