ChristineT
Aug 15, 2018NETGEAR Employee Retired
Looking for a select group of Orbi Community members that are interested in beta testing firmware
Greetings Orbi Community,
We are looking for a select group of Orbi Community members that are interested in beta testing current and upcoming Orbi firmware to help broaden our scope of use cases in real environments. We are kicking off this beta testing program with OrbiOS Rel. 2.2 that is currently available for testing. This release contains the following:
- Significant bug fixes for stability & performance
- Update on Guest WiFi Schedule usability
- Update as of 8/22/18: Upon further investigation the Guest WiFi Scheduling feature has been removed from this release as it requires further testing. We will reintroduce this feature in an upcoming release. We sincerely apologize for any inconvenience this may have caused.
Please note: This Beta Firmware is available only for RBR50 & RBS50. Beta firmware for other Orbi systems will be available soon.
If you’d like to participate and provide feedback in our Orbi Beta Firmware Community please post a reply to this topic with “I’d like to participate in the Orbi Beta Firmware Community” or send a private message to Christian_R to be granted access. By requesting to participate, you agree to share your feedback strictly within the Orbi Beta Firmware Community. You will receive a private message once your username has been added as a participant.
We look forward to working with you!
Orbi Team
- GeegmanAspirant
Everything is at 2.2.1.210 with the outdoor at 2.2.1.204.
just tried changing to ap mode then reset router to factory and switched my xfinity router back to bridge mode. All fresh settings and wireless drops often. Tried everything since purchase last winter but nothing seems to work. Tempted to go back to my old access points and extenders. Any hope? I see I’m not the only one with the same problems.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Might try a full FW manual load as well as a last resort:
- jaysvaneAspirant
I would like to participate in the beta firmware testing. The Orbi is constantly disconnecting from the internet.
- jaysvaneAspirant
And how do I do that?
- crcerdaAspirant
- La1974Aspirant
Please, count me in.
Update on Guest WiFi Schedule usability- Update as of 8/22/18: Upon further investigation the Guest WiFi Scheduling feature has been removed from this release as it requires further testing. We will reintroduce this feature in an upcoming release. We sincerely apologize for any inconvenience this may have caused.
If you’d like to participate and provide feedback in our Orbi Beta Firmware Community please post a reply to this topic with “I’d like to participate in the Orbi Beta Firmware Community” to be granted access. By requesting to participate, you agree to share your feedback strictly within the Orbi Beta Firmware Community. You will receive a private message once your username has been added as a participant.
Orbi Team
- crcerdaAspirant
- marcpvAspirant
please send me the beta firmware my router is very unstable
- I’d like to participate in the Orbi Beta Firmware Community.
- ductapempireInitiate
- On this new beta firmware Router Firmware Version V2.2.1.210 release I have noticed that the Orbi in router mode is not saving some of my static ip addresses for some of my wi-fi cameras. After a normal reboot they come back with a different ip address and I cannot connect without updating the new address. Just my observation and FYI. Otherwise been running smoothly since its release.
- AneuraAspirant
My Setup: AT&T Uverse 1000 > Model:RBR50|Orbi Router + 2 Satellites
- Gary_AGuide
I’d like to participate in the Orbi Beta Firmware Community and test the latest beta firmware.
Thank you.
- obigunkenobiAspirant
I returned my orbi so I am no longer interested in the beta program
- tom_vAspirant
