myraid1
Feb 15, 2018Aspirant
Looking for buy Netear Orbi RBK50 - few questions
Hi. I am new to the community but have narrowed down my search for a 'mesh' WiFi system for my house. A bit of background on my configuration; I have a Sagecom modem/router that sits central in t...
tsig
Feb 15, 2018Luminary
recently installed my orbi system as an AP. Simply unboxed it, synched up the satellite, went into my existing router and turned off its wifi and changed the ssid and password on the orbi to my old one. Everything but my HP wireless printer connected no problem. Had to reset and then connect the printer. Been completely happy for several weeks now.
- myraid1Feb 15, 2018Aspirant
Thanks for the quick reply. Are you happy with the speed? Also, is there nothing you need to change in the setup to set the Orbi as an AP?
- RoamaboutFeb 15, 2018Luminary
I have a similarly large and complex environment. Given the current instability of the wired backhaul I would not underestimate the speed and stability of the wireless backhaul between the Orbi sats and the Orbi router. I have my Orbi router in the middle of a large-ish house wired into a 24 port switch in the basement but the two sats are wireless in the far extremeties of the upper floor.
I only have 50mpbs service from Verizon but I can max out that connection from any location in the house over wifi using any 5Ghz device.
Roamaboutwrote:I have a similarly large and complex environment. Given the current instability of the wired backhaul I would not underestimate the speed and stability of the wireless backhaul between the Orbi sats and the Orbi router. I have my Orbi router in the middle of a large-ish house wired into a 24 port switch in the basement but the two sats are wireless in the far extremeties of the upper floor.
Thanks. I have read quite a bit about the issue with the wired backhaul which has me reluctant to purchase. That being said, I too only have wireless 50mbps at the moment so hearing you are maxing out that speed in all corners of your house is promising. Instead of directly connecting it to my switch however I will hard wire connect it directly to my service provider modem/router and then position the other satellite some place in our finished basement. I see you have a three box system vs the two box. I was just considering the two box system for our ~3600 sq ft house. You think I should consider the three box system for this size?
- tsigFeb 15, 2018LuminarySpeed has been great. It comes set up as a router, so yes you do need to change it to AP mode.
