myraid1
Feb 15, 2018Aspirant
Looking for buy Netear Orbi RBK50 - few questions
Hi. I am new to the community but have narrowed down my search for a 'mesh' WiFi system for my house. A bit of background on my configuration; I have a Sagecom modem/router that sits central in t...
Feb 23, 2018Guru - Experienced User
Ah I see you have a Sagecom 5250. This is a gateway router I believe. I recommend using it in bridge mode. If not, use the DMZ on the modem for the IP address that Orbi router gets from the modem. Helps with double NAT issues that can cause problems. I see you maybe getting Fiber as well. Keep this in mind.
- myraid1Feb 23, 2018Aspirant
FURRYe38wrote:Ah I see you have a Sagecom 5250. This is a gateway router I believe. I recommend using it in bridge mode. If not, use the DMZ on the modem for the IP address that Orbi router gets from the modem. Helps with double NAT issues that can cause problems. I see you maybe getting Fiber as well. Keep this in mind.
You are correct, it is a gateway router. That is a great tip on bridging. Thanks a lot. I will give this a try. Too many folks "stress" testing the system as we speak so will have to hold off for a bit. Thanks again.
