myraid1
Feb 15, 2018Aspirant
Looking for buy Netear Orbi RBK50 - few questions
Hi. I am new to the community but have narrowed down my search for a 'mesh' WiFi system for my house. A bit of background on my configuration; I have a Sagecom modem/router that sits central in t...
myraid1
Feb 23, 2018Aspirant
FURRYe38wrote:Yes of course. One think I would do, use the DMZ on the modem for the Orbi router. Do this and will help mitiagate connection issues.
Enjoy. :smileyhappy:
Fair enough. Curious, when using DMZ do you any sort of firewall? Am I not opening up a risk since I am not assigning a specific port?
Feb 23, 2018Guru - Experienced User
DMZ is ok to use since you want the Firewall on the Orbi router handle issues. IN your case, you want DMZ on the modem and not using two firewalls. Just one is needed. The Orbi will handle all firewall problems.
- myraid1Feb 23, 2018Aspirant
FURRYe38wrote:DMZ is ok to use since you want the Firewall on the Orbi router handle issues. IN your case, you want DMZ on the modem and not using two firewalls. Just one is needed. The Orbi will handle all firewall problems.
Makes sense. Will try that setup shortly. Cheers
- FURRYe38Feb 23, 2018Guru - Experienced User
:smileywink:
- myraid1Feb 24, 2018Aspirant
So one question I have is that I notice that from time to time one of my satellites begins to flash the white light. May happen for a few seconds and then stop. Is this because it is searching for the router? Should this be happening? Some devices seem to be connected to it and functioning fine but was just curious if I should consider moving it somewhere else.
Thanks
