RAE1973's avatar
RAE1973
Looking to buy The ORBI OUTDOOR Range Extender but will it work?
I currently use an AC900 Nighthawk R7000 router and it covers my entire home quite well except for one issue. Outside on the patio it works well when the sliding glass doors are open, but when they are closed it's hit or miss and does not always work. I am guessing this has sometjhing to do with the sun film in the doors which I am also assuming may be a metallic film but don't know. Will the ORBI outdoor Range extender solve the problem? Or will I be running into the same issue when the patio sliding glass doors are closed?
  • FURRYe38's avatar
    Orbi out door RBSY models only work with Orbi systems. They won't connet to other NG routers.
    • RAE1973's avatar
      RAE1973
      interesting, the netgear website says it can connect to the Nighhawk R7000
      • CrimpOn's avatar
        CrimpOn
        Maybe we are talking about different devices.  The Orbi RB50Y is what we think of as the "outdoor" unit.  I looked at the product web page, and did not see a reference to connecting it to the Nighthawk line. https://www.netgear.com/orbi/rbs50y.aspx
        Is this the unit you are talking about?
        Can you send a link to the reference?
        Thanks
