jgv11
Nov 18, 2018Aspirant
Looking to get an Orbi system - please help!
Hi all,
I'm looking to get an Orbi system for my home.
My home has ethernet ports in every room - so I each Orbi satellite would be connected to an Ethernet port.
I just wanted to c...
- Nov 18, 2018
Yes, with this configuration you will have a wired backhaul. I think this would give your system the most possible stable backhaul.
Please make sure to sync your satellites with the router before connecting the cables so you will have the wireless backhaul as a backup in case anything happens with your wired network.
ekhalil
Nov 18, 2018Master
Yes, I think this setting will work perfectly.
Is the 16-port switch a managed switch? If yes then it's preferable to disable all IGMP protocols on the switch.
- jgv11Nov 18, 2018Aspirant
Thanks so much!
Just to confirm - would this configuration mean there is wired backhaul? Would this be the fastest possible setup?
- ekhalilNov 18, 2018Master
Thanks mate, you're a legend.
