jgv11's avatar
jgv11
Looking to get an Orbi system - please help!
Hi all,   I'm looking to get an Orbi system for my home.   My home has ethernet ports in every room - so I each Orbi satellite would be connected to an Ethernet port.   I just wanted to c...
  • ekhalil's avatar
    ekhalil
    Nov 18, 2018
    Yes, with this configuration you will have a wired backhaul. I think this would give your system the most possible stable backhaul.
    Please make sure to sync your satellites with the router before connecting the cables so you will have the wireless backhaul as a backup in case anything happens with your wired network.
