rxhinton
Mar 20, 2021Aspirant
Loses internet every 2 days
I have had my router almost a year now and have had no problems until now. The router loses internet connection. I reboot and it works for about 2 days, then stops again. The firmware is up to dat...
Mar 20, 2021Guru - Experienced User
Is traffic meter or DST under NTP settings being used.
Try a factory reset and setup from scratch before downgrading. Don't use Traffic Meter.
What is the brand and model# of the ISP modem or ONT the RBR is connected too?
rxhinton
Traffic meter is being used although I never look at it. I have used 3 different modems, both experience same problem
Netgear CM700
Arris Surfboard SB6190
forgot the other one
Unfortunately I thought it was a modem problem and spent an unnecessary $200.
- FURRYe38Mar 20, 2021Guru - Experienced User
Ok, well someone said Traffic Meter is causing problems. I would disable it if your not really using it anyways.
There are known problems with the SB6190 modem. Something you may want to review:
rxhinton wrote:Traffic meter is being used although I never look at it. I have used 3 different modems, both experience same problem
Netgear CM700
- vajimMar 20, 2021Master
If you'll do a search....you'll see 100's of folks complaining about the same
you may want to consider rolling your firmware back
- vajimMar 21, 2021Master
