Tchalk's avatar
Tchalk
losing ISP connection - after V2.5.1.16 update
My Obri system lost its connection to the ISP for no apparent reason (Comcast didn't have an outage) two days in row around the same time of day in the afternoon. Both times I have rebooted and it starting working again. This issued started after updating firmware to the most recent V2.5.1.16. Is this an issue for others? Other than this recent issue, my setup has been working great for a year or two now.
Possibly related, the distance between my satellites and router are pretty far. I am back hauuling an ethernet connection to a natural switch. Should I be enabling the " Enable Daisy-Chain Topology?" I'm wondering if I had it enabled before and after update it got unselected and it causing a crash of sorts?
Thank you everybody,
Tyler
  • FURRYe38's avatar
    I
    What is the Mfr and model# of the ethernet switch in the configuration?
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    What is the distance between the router and satellite(s)?
    • Tchalk's avatar
      Tchalk
      Thank you, Furry,
      I just enabled the Beamforming and MIMO and it's now working. My outdoor office is about 40 feet from the house with a trenched ethernet cable going to the satellite back to the switch. Other than mesh wifi not working well with RING security and Yale locks, the system works great. Here's a pic of my setup... that I'm unable to upload?
