rulli61
Aug 16, 2018Aspirant
Loss of internet after power trip
I recently had a circuit trip where I have a orbi satellite connected via daisy chain. The main router was unaffected by the power trip. When the power was restored I was unable to connect to the inte...
Aug 16, 2018Guru - Experienced User
What FW is currently loaded?
Any network switches in the mix? If so, Mfr and model#?
Satellites wireless connected to the router?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Setup an IP adderss reservation for each satellite ON the router.
Also:
https://community.netgear.com/t5/Orbi/My-Ethernet-Backhaul-Setup/m-p/1625276#M39379
rulli61
Aug 26, 2018Aspirant
I’m not that savvy when it comes to network settings, the same issue happened again today. What happens is if I have a power trip somewhere ,when the circuit is restored it is causing a conflict between the satellite Orbi and the router ,as if the issue is with my IP, but it isn’t but it’s saying there is no internet. When the “daisy chain” is removed from the satellite and all orbi are rebooted it then rejoins the internet. So the issue is when it tries the link via Ethernet there is some sort confliction between the units. I am running most recent FW. I have better connection with daisy because of the construction of my house
- FURRYe38Aug 26, 2018Guru - Experienced User
I would set up IP address Reservations for the satellites and ALL other connected devices ON the router.
