amys's avatar
amys
Lost connection to Samsung Smart TV and can not reconnect - unable to connect to internet
I have a CM400 Modem and Orbi AC2200 Wifi. I had no problem setting up my Samsung UN55MU6290FXZA Smart TV back in December. I was able to connect to the internet and stream media. Recently I lost my internet connection. I am able to connect to my orbi Wifi but the Samsung TV has an X when trying to connect to the internet. I have been on the phone with Samsung and we are able to connect to the internet with a hotspot. So they say it is not their issue. I have been on the phone with Comcast and because all my Vizio TV's work they say it is not their issue. I have tried every fix possible online. Power. Reset. Factory Reset. Manual DNS and even Sync/WPS. I can not get the TV to connect. I am out of ideas. Any help would be appreciated. The TV is only 3 months old. I see online this is a common issue but most can resolve with the fixes above.
  • michaelkenward's avatar
    michaelkenward
    This is a wifi connection from the router to the TV?
    Did your reset include the TV?
    My experience is that these things are usually down to the TV setup. That's why I ditched wifi in favour of powerline ethernet.
  • FURRYe38's avatar
    What channels are you uisng the Orbi router?
    Try manual channel 1, 6 or 11. Any unused channels on 5ghz.
    Any other wifi neighbors near by? If so, now many.
    Try disabling Beamforming, MIMO, Daisy Chain and Fast Romaing under Adv/Adv Settings/Wireless
    • amys's avatar
      amys
      Thanks all. A few weeks ago I relocated my modem and router. It was only a few feet.
      I moved it back to where it was and it solved the problem. I must have been out of range.
  • FURRYe38's avatar
    Glad you got it working again.
    Might see if you can connect the TV to the ethernet port either at the router or Satellite in the future.
    Enjoy.
