creaky
Oct 28, 2016Star
lower signal strength after update to V1.3.0.12
 After I updated to the V1.3.0.12 firmware, my signal strength has degraded from what I presume is the router. I used to get full bars while on the floor where the router is located (and I'm usually a...
peteytesting
Oct 31, 2016Hero
try factiry resetting the orbi system and re do the initial setup as this may fix the issue
pete
