Barry144
Jan 25, 2018Follower
Lyric thermostats
I have two lyric round thermostats that I can not get to connect with Orbi. They seemed to work fine with my prior wifi router. Apparently this occurs with Nest also. I have rebooted the thermostats ...
st_shaw
Jan 25, 2018Master
You could try to set separate SSIDs for 2.4 and 5 GHz and see if it connects OK then.
rhester72
Jan 26, 2018Virtuoso
The "with my prior router" part suggests to me that the subnet and/or encryption you used to use is different from Orbi's. You'd probably do well to factory-reset the affected devices and set them up from scratch.
