holarsen
Feb 27, 2019Aspirant
M4300 Inter-VLAN routing
New Orbi RBK53 fully updated (2.2.1.210) & GSS116E - ProSAFE 16-Port Gigabit Click Switch
Hi Guys,
This is my first time here and I hope I can get some input from you all. I have a Fibre...
- Feb 28, 2019
holarsen wrote:
- This setup works for almost everything - WiFi and cabled network users have fast and reliable network, the Guest network works perfectly - the only thing that sofar isn't working is my QNAP NAS and the DDNS i relies on for updates, which influences the software updates of the NAS. I had a very similar setup working with a somewhat unstable TP router, where the WiFi simply was insufficient for the building, and now with my lovely new Orbi I can't get the last bit to work...
I would really appreciate some input on where my problem might be.
You probably don't need to add static routes, it's may be enough to just activate RIP in the LAN setup as follows (please try RIP_2B, if RIP_1 does not work):
ekhalil
Feb 28, 2019Master
holarsen
Mar 03, 2019Aspirant
Thanks, I will test
Best regards
