Easton10800's avatar
Easton10800
MAC Address
I have a mac address that continues to attemp to connect to my network which I have blocked.  I believe it may be assoicated (due the similar mac address) with either the router or satellite but I cant figure out for sure.  Any way to find this out?
  • CrimpOn's avatar
    CrimpOn
    On the Orbi web interface (http://orbilogin.net), the Attached Devices page shows the MAC address of every device connected to the Orbi, including the satellite.  If the Orbi satellite is functioning, then that MAC address is probably not the satellite, which is easy to confirm.
    One suggestion is to record that MAC address and look it up on one of the OUI databases, such as Wireshark:
    https://www.wireshark.org/tools/oui-lookup.html
    Once you know which manufacturer the MAC address is assigned to, that may provide a clue to which device this is.
      • CrimpOn's avatar
        CrimpOn
        Since it is not connected, can you post the MAC address?
