marty1964
Jul 25, 2021Follower
MacBook Pro keeps disconnecting to wifi at random intervals
my model RBR50 keeps disconnecting when accessed with my macbook pro.It happens frequently but only with my laptop and ipad.Not with my other android devices.I tried factory resetting but the problem persists.Any other options?
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Do you have Armor or Circle enabled?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
