pup0975
Sep 27, 2018Star
Macbook speeds capped at 30-40mbps
I am on 2.1.4.10 and it has been pretty solid except my Macbook speeds are capped at 30-40mbps on my 100mbps internet service. All of our other iPhone/iPad speeds are fine. If I turn off and turn bac...
- Sep 28, 2018
How are you turning OFF each radio? The radios need to be enabled and turned on for the system to work right and perform well. This is a mesh system intended to have all radios running since this is how mesh systems work. I've had zero issues with my system since day one. So has my friends system I set up for him:
This is not a FW issue if your disabling wifi or you don't have the wifi configured correctly.
I would ask about the new beta FW, some mentioned that it was working better:
Orsuna wrote:
I have been running the default settings for 2.4GHz with the 5GHz turned off in AP mode for the past 4 months without issues until I dropped the 2.1.4.16 firmware on it 3 weeks ago. It's ruined my ability to livestream video to the internet, and as of last night, I shut off the 2.4GHz radio and switched my entire router/satellite to 5GHz and now I'm back to 140+ Mbps speeds on my wireless devices. It's definitely something within the 2.1.4.16 firmware that is affecting the wireless speeds. It seems as though if the 2.4GHz band is enabled, the performance is degraded on the Orbi system.
Sep 28, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
I changed the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
pup0975 wrote:
I am on 2.1.4.10 and it has been pretty solid except my Macbook speeds are capped at 30-40mbps on my 100mbps internet service. All of our other iPhone/iPad speeds are fine. If I turn off and turn back on the Wifi on the Macbook, I get the full speed. It "resets" when I put the Macbook to sleep. I've got 3 Macbooks (on High Sierra and Sierra) and all 3 do the same thing. I haven't updated to 2.1.4.16 because I saw someone else had this issue on the 2.1.4.16 thread. I didn't want to mess something up by updating the firmware. Wanted to see if more people have this issue or if there is some setting change that will fix this.
- OrsunaSep 28, 2018Aspirant
- FURRYe38Sep 28, 2018Guru - Experienced User
